difference between dx and si tranny
Old May 24, 2007 | 06:26 PM
BlueRex1020's Avatar
Default difference between dx and si tranny
hi guys, i'm buying an si tranny tomorrow for my dx rex but i want to make sure its an si tranny so i dont get screwed over....How can i tell if its an si tranny? what code should i look for?
Old May 24, 2007 | 06:29 PM
garageEF's Avatar
Default Re: difference between dx and si tranny (BlueRex1020)
dx and si codes are the same... you have to rotate it to determin the ratios. look in the FAQ... there is a write up on it.
Old May 25, 2007 | 04:37 AM
vdawg559's Avatar
here u go buddy. https://honda-tech.com/zerothread?id=1551508
Old May 25, 2007 | 02:40 PM
nihad's Avatar
Default Re: (vdawg559)
1 gear is longer on dx but they are basically the same.
Old May 25, 2007 | 07:02 PM
welfarepc's Avatar
Default Re: (nihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">1 gear is longer on dx but they are basically the same. </TD></TR></TABLE>
they are not the same at all... si has a different final drive and bearings
si is much better, ive had both
edit: https://honda-tech.com/zerothread?id=1551508
Modified by welfarepc at 8:20 PM 5/25/2007
Old May 25, 2007 | 11:45 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (welfarepc)
1-5 ratios are the exact same on the dx and si. the final drive is the only difference. 3.88 for the dx, 4.25 for the si.
4.25 will make your car accelerate much faster.
the best way to tell, as someone mentioned, is to rotate the input shaft and observe the rotation of the differential. its in the faq at the top of the page.
Old May 26, 2007 | 01:22 AM
vdawg559's Avatar
heres teh fact right here yall for all the car gear rations... keep the site link.. u might need it
http://www.knology.net/~jedikl...s.htm
lshatch1.8
24
Jan 19, 2006 09:39 PM
JaHnAbOi
31
Sep 28, 2005 08:41 PM
DOHC_EF
Jul 13, 2004 06:06 AM
CrxSi707
May 25, 2004 08:56 AM
serious
14
Jul 17, 2002 03:31 AM
