Crank pulley tool, The wrong one???
I have a D16Z6 in my crx and I'm trying to change the timing belt. I seem to be stuck at getting the crank pulley bolt off.
So I bought this tool but it turns out that my crank pulley does <U>not</U> have the hex-shape cut out for this thing.
Is it the wrong tool or am I missing something obvious
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 »</TD></TR><TR><TD CLASS="quote">Some pullys don't have the hex, nothing to miss you're just SOL...
This is what I was dreading but thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">You need the other one they sell</TD></TR></TABLE>
ARGH. I will look into this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yip Man »</TD></TR><TR><TD CLASS="quote">Hmm that doesnt even look big enough for a crank bolt. How would it fit on their isnt the pulley bolt inside the pulley also?? You are talkin about the underdrive pulley right</TD></TR></TABLE>
It's actually a big honkin wrench my man. It doesn't look like it in the pic, but thats actually a 3 foot wrench ..
...THAT DOESNT FIT
*emo*
</TD></TR></TABLE>This is what I was dreading but thank you
...THAT DOESNT FIT
*emo*
I dont see any other tool on their web site
Help?
Help?
does your pulley have holes in the middle? if so, i think theres a tool that bolts to those holes rather then the hex shape. p.s. i would keep the tool you bought and just upgrade your curent pulley to one that has the hex shape...makes life so much easier!!
just bring it to a shop with a big 1" gun and have em blast if off then put it back on just not as tight so you can get it off at home
I'd definately keep that tool and get a crank pully that has the hex in it for when you put it back together. I've never heard of a tool to fit in the holes, but I remember reading a thread around here somewhere where they just jammed a screwdriver through the hole to hold it. It apparently worked but it tore up the pully (which wouldn't matter if you wre gonna replace the pully with a hex one).
I think I will get that pulley. In the meantime, I'll probably make my own tool to fit in the holes and lock up against something in the motor bay. I'll also look in to getting the starter motor off but I think making my own tool won't be that bad since I have access to CNC anyway.
Thanks dudes
Thanks dudes
SuicideSlide
Oct 9, 2004 08:27 AM
