no brake pedal
Hey guys, I have a brake problem. I purchased my coupe and everything was good. Test drove it and brake were fine. well when i got back to my home town i pulled the e-brake for parking reasons. WHen i got back in the car to drive it. No brake pedal. I BARELY have any brakes until the pedal is pretty much to the floor.
Checked the fluid level....Full....
Acts like there is air in the lines....but i dont see how considering it worked fine before i pulled the ebrake...any ideas?
i would suggest bleeding it first. if you still have drums in the rear check to see if your wheel cylinders are leaking, it can somtimes cause the pedal to act up. most likely though it might be your master cylinder. so just check out your brake system first to eliminate anything else. if it's all fine slap in a master
Chev
14
Oct 20, 2017 03:32 PM
stripes777
Oct 28, 2006 11:16 PM
