accord type-r head
Old May 24, 2007 | 03:44 PM
Vilmar's Avatar
Default accord type-r head
Can I put accord type-r (euro h22a7) head to my jdm h22a ? does it bolt right up on?
Old May 24, 2007 | 04:41 PM
Mydogisgone's Avatar
Default Re: accord type-r head (Vilmar)
Yes it's the same, only the a better flowed head and camshafts.
Be sure you mill before putting it on the block.
Old May 24, 2007 | 06:36 PM
Vilmar's Avatar
Default Re: accord type-r head (Mydogisgone)
Yes thank you, I knew it would flow better and that stuff, but wasn't sure if it would bolt right on
Old Feb 6, 2008 | 08:19 AM
Vilmar's Avatar
What headgasket should I use? the h22a7 one or the original '97+ prelude gasket??
Old Feb 6, 2008 | 08:22 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mydogisgone &raquo;</TD></TR><TR><TD CLASS="quote">Yes it's the same, only the a better flowed head and camshafts.
Be sure you mill before putting it on the block. </TD></TR></TABLE>
why would he mill it?
Old Feb 6, 2008 | 08:42 AM
jdmbreed's Avatar
Default Re: accord type-r head (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
why would he mill it?</TD></TR></TABLE>
2x??????
Old Feb 6, 2008 | 08:45 AM
98vtec's Avatar
moderator emeritus
Default Re: accord type-r head (jdmbreed)
i understand getting it checked for straightness and maybe a resurface, but milling an expensive head is not the way to go. If you want to drop the compression, run a thinner gasket. Atleast that way you can return it back to normal.
ep4life
Mar 13, 2008 05:16 AM
93civicjaydm
Honda Civic (2006 - 2015)
Feb 22, 2008 01:16 PM
xxnuttybarxx
Aug 27, 2007 02:20 PM
Turbo_y8
Feb 25, 2006 07:11 PM
walkerklondyke2000
Jan 12, 2006 10:11 PM
