How do you disconnect your powerlock button, if you can?
Removing the fuse would totally disable the power lock mechanism. If you want to prevent the switch from functioning, just unplug it. If you want to totally remove the switches and achieve a cleaner look, you can order a pair of RS handle bezels, which do not have a switch at all.
stinkypinky1011
21
Nov 11, 2013 11:18 PM
