92 accord - fuel pump or distributor bad?
Old May 24, 2007 | 12:26 PM
bochnak's Avatar
Default 92 accord - fuel pump or distributor bad?
My car died during cruise. I pulled over and it cranked more than usual, but fired right up.
Has newer main fuel relay and fuel filter. Ignition sytem (plugs, cap, rotor) are in good shape.
I wondering if I have a problem with my fuel pump or distributor going bad.
Where is the fuel pump located? Under the rear seat? Also, if the distributor is going bad, would it be problematic intermitently or go for good?
I want to get ready to diagnose this problem next time it happens. I will have tools to check for spark and have access to the fuel pump.
Thanks,
Matt
Old May 24, 2007 | 02:01 PM
standbackimapro's Avatar
Default Re: 92 accord - fuel pump or distributor bad? (bochnak)
The Distributor can Cause intermittent Problems, but it can Also Just stop functioning at anytime..
I doubt its the fuel pump, Most likey the distributor, ive seen nearly 200 90-92 accord Distributors have the same problem
Old May 24, 2007 | 04:35 PM
bushrat's Avatar
It sounds alot like an igniter to me. Been lots of posts on it.
Cheers
Old May 25, 2007 | 04:03 AM
bochnak's Avatar
Default Re: 92 accord - fuel pump or distributor bad? (bushrat)
The igniter was the culprit. It died on me several times on the way home from work. Luckily, the symptoms occurred in my driveway and was able to test for spark. I found no spark from the coil terminal. Tested coil and it was good.
I guess the igniter tells the coil when to spark. My buddy owns a shop and he had a used OEM igniter that he gave me. Runs great now.
BTW, the distributor looks newer and non-OEM. The shaft was tight with no play.
-Matt
Waldron Racing
Nov 26, 2013 06:45 AM
go2sleep
May 4, 2007 07:19 PM
junya16
Mar 13, 2003 09:14 PM
Accord1980
Jan 29, 2003 01:28 PM
