FS: Garrett GT30R .60/.63AR T3 3inch V-Band GT3076
For sale i have a Pretty Much New GT30R by Garrett IT has a .63AR T3 housing in a 3inch V Band Exhaust Outlet. Perfect setup for manifold and downpipe i am selling.
I purchased it in January 2007. Turbo has maybe 2000 miles through it and Ran only Mobil1 Fully Synthetic Oil Through.
Perfect Condition. No Shaft Play No Leaks.
Here are the Specs:
Dual Ball Bearing GT30R Turbo assembly with T3 style housing with T3 inlet flange w/ 3" V-Band Exit. T04E style compressor housing with 4.00 inlet and 2.00" outlet. Very Good response turbo for 4 Cyl applications. This turbo has a flow capacity of about 500HP. This turbo would be the same as HKS GT3037. The GT30R turbine housings are made out of ductile Ni-Resist iron (has a nickel content of about 38%). This material is much better at withstanding high exhaust gas temperatures than regular cast iron.
Turbine
-Wheel: 60mm w/ 84 trim
Housing: .63 ar
Compressor
-Wheel: 76.2mm w/ 56 trim
-Housing: .60 ar
Turbo Made 505whp at 28 psi c16. and 375whp at 18 psi 93 Octane.
I purchased the turbo from ATP Turbo for 1300 shipped
Will sell for $1000. Remember this turbo was just purchased in January 2007 and used for about 2000 miles if that.
Here are the Specs:
Turbine
Housing: .63 ar
Compressor
-Housing: .60 ar
