Build a roll cage at home
When we made a fram at school for the FSAE car we had mills and lathes to "fish mouth" tubes and we had the roll hoops bent at a local shop. How are people doing this at home i could see maybe using a hole saw but i don't know how well this would work vs a end mill.
Just wondering if it is worth while to make your own i think they would fit better then a kit but i want hear from the experts.
yeah that would work. Does anyone bend the roll hoop at home?
i found this
http://www.tubing-benders.com/tubing-notcher.html
i found this
I built a tubing bender similar to the one found on blind chicken racing:
http://www.blindchickenracing....r.htm
it worked very well and cost about $350 to build including die and jack cost.
I also have the JD2 tubing notcher and that worked great as well.
http://www.harborfreight.com/c...42324
Easy
Any welder can weld a roll cage, but you have to make sure its in specs and the welds are going to hold up incase of a roll over or crash..
Easy
ToxicFabrication
Welding / Fabrication
39
Jan 8, 2009 01:57 PM
SwappedTURBOegg
123
Nov 10, 2008 04:07 PM
Bova (K-ek)
Aug 10, 2005 04:46 PM
Rob Dizzle
13
Apr 4, 2004 12:10 PM
