ATF FLUID CHANGE HELP
Old May 24, 2007 | 07:43 AM
Integra9000's Avatar
Default ATF FLUID CHANGE HELP
Its and 2001 Gs Teg. i took the flippin wheel off and the bolts for the drain and all are different then the manual integra. can someone tell me how to change the tranny fluid in this car, i already have honda atf fluid. Just need the mechanics on it.
thank you gues and please help me with my noob of a question.
Old May 24, 2007 | 10:42 AM
nitrofish420's Avatar
Default Re: ATF FLUID CHANGE HELP (Integra9000)
The drain plug should be the same as a manual, a 3/8ths female square head that you can get loose with a 3/8ths ratchet. It should be located in a similar position as a manual, going in from the pass. side on the bottom of the trans. I can't remember the last time I drained ATF on a Integra, but my CRX is exactly like that, and I don't think they're much different from the Teg units.
EDIT: BTW, you don't have to take the wheel off to get to it.
Old May 24, 2007 | 10:51 AM
Default Re: ATF FLUID CHANGE HELP (nitrofish420)
THANKS DUDE U JUST MIGHT BE A SAVIOR! i didnt realize it was the female. oops brain fart. the manual im positive is male though. i could be wrong i just think thats what i remembered
ecarfar
Honda CR-V & Element
May 2, 2017 05:26 AM
Heat
Sep 7, 2005 12:10 AM
DamonBoost
Oct 27, 2001 02:28 AM
