Where are the grounds? -- 91 Accord LX
I'm having trouble with the main relay on my 91 Accord LX. When you turn the key to "on" it makes the clicking noise.
The relay is working fine, and I pulled it out and re-soldered it.
But it still doesn't work. A few people have suggested checking the grounds.
But I'm having the problem of finding all of the grounds. Does anyone have a picture or diagram of the grounds so that I can check them all? Specifically the thermo ground.
Thanks in advance!
Modified by Flatland2D at 8:08 AM 5/24/2007
Thanks in advance!
Sorry. It's the main relay that is making the clicking noise. I've already soldered it, but we're still having the problem.
Anyone? Would it be possible that the thermo ground isn't there? I looked on/around the fuel intake and still can't find it.
We've had this car for a month and have never messed with the grounds. and it has started before.
Is it possible that it started before even without the thermo ground? If it could ground thru another ground that isn't there.
Does this make any sense?
jma1_nemo
Feb 6, 2007 10:29 AM
slowturtle
Feb 28, 2003 09:00 AM
