So it begins.... (pics)
Time for a rebuild! I'm rebuilding because i've been burning a lot of oil and i'm planning for boost this summer! Block is being done by Extreme Parts in Wisconsin. Here are some pics.....you can see cylinder number 3 was definitely part of the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSROWNSU »</TD></TR><TR><TD CLASS="quote">
Is that a bolt (that you can remove) in the block above and to the right of the oil filter flange?
</TD></TR></TABLE>Is that a bolt (that you can remove) in the block above and to the right of the oil filter flange?
I was just wondering because it's a port for the cooling line to the OEM Honda oil cooler (that you don't have).
I've never seen the intake side of a '98+ block before in full form, straight out of the engine bay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidsafe yee »</TD></TR><TR><TD CLASS="quote">damn. wtf happened to cylinder 3. lol</TD></TR></TABLE>
little oil burning anyone?
lol this is what gave me an excuse to rebuild for boost anyways...makes me sad tho i babied this car and for it to burn oil that bad it had to have gotten the **** beaten out of it by the previous owner
o well she'll be good as new in a couple weeks
You can add the oil cooler. You need the oil cooler, the water pipe, hoses, and the hose adapter for the bolt mentioned earlier. Just look up the parts for the 94-95 GSR or the ITRs. You need an extractor to remove the stock oil filter mount bolt, which is replaced with a longer bolt that passes through the oil cooler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ice-Nine »</TD></TR><TR><TD CLASS="quote">Where is Extreme Parts in Wisconsin and if you don't mind, how much is it running you to get it rebuilt?
Curious cause I eventually want to rebuild mine.</TD></TR></TABLE>
I would like to know also.
yea it's not as bad as you think the flash on the camera wasn't working...brightened them up in photoshop. Right now there are just 4 100 watt bulbs in there so lighting is low but i have some fluorescent lights coming when we insulate everything...it's brand new
They are located off of hwy 20 in racine close to the lakefront. http://www.extremeparts.com
As far as the build i am getting je pistons (-1.17 dish) bored .025 over with hone and hot tank, new rod bearings, bottom end gasket kit, and blueprinting/assembly. They are doing it for a little less than 1300 parts and labor
