Car wont start
I search already...some of the post help but didnt give a answer. Heres the problem, i have a 91 accord ex 5 speed. When i go to start the car it will act like im not pressing down on the clutch..i try bypassing the clutch, new starter, batt, alt, grounds. My car will start if u turn the key to acc and jump the starter straight from the battery.
I had another guy on cb7tuner tell me that he had the same problem and it was a little black box on the pass. side of the dash, something about a anti start device. Oh and i change out the main relay already so its not that.
TIA
TIA
Sounds like ignition "tumbler" Has it been hard to turn your key to START lately? If so.....
Remove steering column cover.
Turn key to RUN.
Push button on bottom of key cylinder.
Pull whole thing out.
Use screw driver to start car(Like a big geto key)
Go to NAPA.
Get new one (arround $25)
Tell the clerk Thank you!
Put new one in.
Go home.
Turn key to RUN.
Go to NAPA.
Put new one in.
Go home.
its not hard to turn the key at all...but i think i might just change out my ignition just cause thats about the only thing i havent done yet..thanks so far...let me change it this weekend and i will update
Armando Galvan
Nov 2, 2012 02:38 PM
UNDER PRESSURE
Jun 21, 2004 08:47 AM
