GETTING AN H22
Good swap? sure...
They're heavy but they've got a GREAT powerband for a DD
Easy? Hell no. Someone probably makes the mounts, but that's one gigantic motor to be stuffing in there.
Trannys that bolt up: H series, F series.
might want to to research it a bit because it doesn't sound like you are up to the task. i am not too sure what is involved but i do know you must go from shift linkage to shifter cables.
Hey buddy, well I have done the H-sawp, but its on a EF CRX and I get the best power out of it. The tranny I used was from an accord Euro-R and it has LSD so I get good power from it. The only problem is that: in what ever car you put it in, you might end-up with axle problems.
You could also do a H2B tranny adapter so you could run B-series tranny.
http://www.explicitspeedperformance.net/
Not only is the h22 a more expensive to buy but god damn an h2b is another grand to get the adapter plate and hardware. And yes the h22 into an EF is a much harder swap.
Hasport makes them but it does require welding, drilling, and cutting. And I also heard that the hasport h22 mounts arent that great some times. There is another company that sells some that have a better rep but you would need to research that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jakscivic »</TD></TR><TR><TD CLASS="quote">Not only is the h22 a more expensive to buy but god damn an h2b is another grand to get the adapter plate and hardware. And yes the h22 into an EF is a much harder swap.
Hasport makes them but it does require welding, drilling, and cutting. And I also heard that the hasport h22 mounts arent that great some times. There is another company that sells some that have a better rep but you would need to research that.</TD></TR></TABLE>
My personal experience is that everyone should stay away from the Hasport EFH22 kit.
No comment on the ESP kit.
My recommendation is to get a great fab shop that's done the swap before to custom you up something.
I love my hasport mounts
No problems at all!
And the car is awsome to drive I think...and I work on hondas for a living.
For a stock motor the thing is wicked fast.....yea the turbo cars and the built NA cars may be faster than it is now....but theres still a ton of room to grow for me.
From installing this thing myself and me being a mechanic by trade....it took me a _solid_ 2 months of working till 11-12 at night after getting off work at 6 and full days on the weekends to get it on the road. Then I took off and headed on a 250 mile trip after getting it running for only 2 days.
That wasn't just putting in the engine it was also painting the entire car and some other mods like rear disc etc. The wiring took me a whole weekend to get it all mapped out and wired in...I think they make jumper harnesses but I wired mine in myself.
If you don't have access to a 2 post lift at a shop or a well supplied home shop I wouldnt even think about it. I even had access to all the used parts I wanted for stuff....I couldn't imagine doing this myself with out working where I work.
If you are gonna do it get a good JDM engine and tranny with LSD...cost a few hundred more but worth it.
No problems at all!
