knock sensor wire
Old May 23, 2007 | 09:04 PM
crxb16ftw's Avatar
Default knock sensor wire
I've already posted about my knock sensor in my b16a. I just got it and went to put it on, and found the hole, but there was no wire to hook it up with. The only wire not plugged in looked like an oil sending unit...and definitely did not fit the knock sensor. Did I get pwned on my wiring harness or I am I just missing it?
Old May 23, 2007 | 09:13 PM
EF_LSVtec's Avatar
Default Re: knock sensor wire (crxb16ftw)
what ecu are you using? just trace the knock sensor wire from your ecu to the sensor itself...and modify the plug.
Old May 23, 2007 | 09:32 PM
daklown's Avatar
Dat Dere Cell Tech
Default Re: knock sensor wire (EF_LSVtec)
ECU is whatever ecu came with a JDM OBD0 B16a...haven't looked at it yet car is fairly new
PROBABLY a PR3
fact: car was bought from a guy pre swapped and needed some work
assumption: he tossed the JDM harness and used stock D harness and under dash harness. hooked up new ECU and didnt add a wire to run to the knock sensor, so all that needs to be added is a wire. IF this is the case...we need a plug to attach to the knock sensor. will anything that just connects and conducts electricity do? or is it easy to locate the harness plug...
Modified by daklown at 12:57 AM 5/24/2007
beginmyhonda
Jul 29, 2009 02:14 PM
phanatic
May 18, 2007 02:21 PM
GR_DC2
Mar 9, 2006 12:29 PM
WOODman
Oct 7, 2005 07:09 PM
devonic
10
Apr 9, 2003 09:53 AM
