Emissions failure, hydrocarbons too high
Old May 23, 2007 | 08:21 PM
danmdevries's Avatar
Default Emissions failure, hydrocarbons too high
Hydrocarbons: Standards = 0.80 GPM. Reading = 1.42 GPM FAIL
CO: Standard: 15.00 GPM, Readign = 4.90 GPM PASS
NOx: Standard: 2.50 GPM, Reading = 2.33 GPM PASS (barely...)
Adjusted TPS
Reset TPS
Initial reading:
Idle: .67v
WFO: 4.61v
reference = .50v @ I, 4.5v @ WFO
New reading:
Idle: .49v
WFO: 4.43v
I also ran the tank vent straight to the IM. Before i had just let it dump through the fender (eliminated evap emissions). State mechanic said HC's can be evaporative emissions as well as unburnt fuel, so I was hoping this would drop it.
Drove the car hard to get the cat as hot as possible. I also went to a different testing station where there wasn't a line, so I got tested with the cat pretty darn hot.
My second test:
HC: 1.48 (up .06)
CO: 4.50 (down .40)
NOx: 1.42 (down .91)
Now I just had the car tuned. My setup is:
D16z6
10.3:1 compression
Ported head
Oversized valves
Stock valvetrain
dc header
Portmatched and polished z6 IM
~100 mi on engine
Running obd1 in a 91 Civic STD hatch off a p72 chipped and tuned, AFR's are all in the right spot thoughout driving range
I have the option of titling it in a different county to avoid emissions altogether and might just do that.
What could be causing the high hydrocarbons if my AFR's are okay, and the cat's obviously doing it's job?
Old May 26, 2007 | 12:37 PM
Default Re: Emissions failure, hydrocarbons too high (danmdevries)
Bump
Old May 26, 2007 | 01:00 PM
Flexmyrex's Avatar
HC is mainly caused by ignition problems, i would check the secondary ignition plugs, wires, cap and rotor. Based on your CO level i would say your car is running on the lean side on the dyno, very lean air fuel mixture is not ignitable even by the best ignition system, a lean misfire also causes unburned fuel to escape which can explain the high HC reading. I would add a little more fuel throughout part throttle cells and do a retest.
Old May 26, 2007 | 01:57 PM
atg1290's Avatar
I had the same problem and saw that i had a hole in my charcoal canister..have not taken it back yet bc i found this out after i had pulled the engine...
Old Jun 5, 2007 | 07:38 PM
Default Re: (atg1290)
Thanks for the responses, haven't checked back on this thread for a while. I went ahead and stripped the car back down and it's in my garage awaiting paint.
I did have some issues with injector wiring that I sorted out before emissions testing, but weren't there while tuning.
There were a few other bugs that I adjusted to be correct, but all after the tune.
I eliminated my charcoal canister and routed my tank vent directly into my IM.
After I'm done painting it, I'm going to have the tuner come back over and throw the wideband on just for another check, see if everything's still where it should be/ see if anything's changed since the initial tune.
Worse comes to worse if I fail the third test I can register it out of state in a county that doesn't require emissions testing.
Old Jun 8, 2007 | 07:25 AM
eg6sirll's Avatar
Default Re: (danmdevries)
check the cat with a pyrometer it should have a 200 - 300 degree difference. also eck map sensor, spark plugs, oxygen sensor , wires cap rotor. etc
Old Jun 8, 2007 | 07:28 AM
eg6sirll's Avatar
Default Re: (eg6sirll)
evap also has nothing to do with hydrocarbons coming out of the tailpipe. all evap does is vent fuel vapors from the gas tank into the engine so they can be burned up. unburned fuel = damage to the oZone
Old Jun 8, 2007 | 10:53 AM
Mike K's Avatar
if your car is obd2, unplug and injector. it'll read less fuel. that's worked before.
if it's obd2, it'll code up.
24TEN
21
Oct 3, 2012 08:21 AM
85mm LS VTEC
Aug 7, 2006 08:40 PM
eg6sir88
Feb 7, 2006 06:20 PM
lelopez
17
Aug 17, 2003 05:40 PM
brinks
May 6, 2002 05:51 PM
