DA has no power 1k-2k rpm???
Old May 23, 2007 | 05:59 PM
91EF_Si's Avatar
Default DA has no power 1k-2k rpm???
Once in a while, my car just struggles through 1k-2k rpm. This only happens in first gear when I'm taking off normal. After 2k it is normal, and takes of nice. It doesn't do it all the time, but when it does I get mad cuz I don't get it. I've changed the fuel filter, spark plugs, air filter, ol change, and it has a new distributor. Any suggestions??
BTW: I have a completly stock 91 RS, with a little exhaust leak.
Old May 23, 2007 | 06:22 PM
91EF_Si's Avatar
Default Re: DA has no power 1k-2k rpm??? (1sickDA9)
bump
Old May 24, 2007 | 03:37 AM
aj223's Avatar
could be your timing. thats whats going on with my 93 ls.
Old May 24, 2007 | 03:51 AM
Lewy. Dee Ayy's Avatar
does it seem like ur car falls flat on its face for a sec..then picks up a little? sound like ur letting out the clutch to fast and not giving it enough gas.
but idk!
Old May 24, 2007 | 07:07 AM
91redteg's Avatar
Default Re: DA has no power 1k-2k rpm??? (Lewy. Dee Ayy)
yeah mine does that sometimes when its not warmed up and im assuming its cuz i let the clutch out to fast
Old May 24, 2007 | 07:34 AM
91EF_Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewy. Dee Ayy &raquo;</TD></TR><TR><TD CLASS="quote">
but idk!</TD></TR></TABLE>
That's exactly what it does...So you think I'm letting the clutch out to fast?
Old May 24, 2007 | 09:05 AM
ABCVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sickDA9 &raquo;</TD></TR><TR><TD CLASS="quote">That's exactly what it does...So you think I'm letting the clutch out to fast?</TD></TR></TABLE>
yes. how long have you been driving manual for honestly?
Old May 24, 2007 | 09:06 AM
91EF_Si's Avatar
Default Re: DA has no power 1k-2k rpm??? (ABCVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABCVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
yes. how long have you been driving manual for honestly?</TD></TR></TABLE>
Like a year...but my other std. cars never did that...
Old May 24, 2007 | 10:29 AM
91slamedrex's Avatar
check ur compression
Old May 24, 2007 | 10:55 AM
ABCVTEC's Avatar
Your clutch is probably just rides really high.
Old May 24, 2007 | 10:59 AM
91EF_Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABCVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Your clutch is probably just rides really high.</TD></TR></TABLE>
I adjusted it so it will grab low. Grabs about 3" off the floor..
dillonG_B
Jan 29, 2008 10:29 PM
AMLS4dr200whp
Oct 4, 2005 08:36 AM
killaj12
Apr 20, 2005 11:06 AM
roadracewade
Nov 11, 2004 12:02 PM
luderzzz
Apr 16, 2004 05:24 AM
