japan model 1990 civic gauge cluster
i have been lookin for 2 days cant seen to find it , iam lookin for the colour wire list of the gauge cluster. ie wat colour wire is for the tac speedo n so on
thanks
thanks
HOW TO INSTALL A JDM EF8/9 SiR (88-91 Civic/CR-X) GAUGE CLUSTER
Information taken from http://b16a.honda-perf.org/cluster.html
INTRODUCTION
The JDM EF8 cluster connects by the use of four connectors. The three main dash connectors being one 6-pin, one 8-pin and one 10-pin. Also a smaller 10-pin colored green or yellow (used for the CR-X diagram in the corner - reminder light for open doors/hatch).
The USDM cluster wires in with the use of two connectors. There is one 12-pin and one 8-pin.
APPLICABLE TO
88-91 CRX Si/HF
88-91 Civic (currently do not have the wiring conversions for)
INSTALLATION
Starting with the 6-pin connector, as if the cluster were sitting in the car plugged in, from the far most USDM Passenger side terminal.
NOTE: Location in the stock harness doesn't matter, just look for the same colored wires. In the USDM CRX, factory manual, the dash connectors are labeled C709 (12P) and C710 (8P).
PIN COLOR FUNCTION 1990 CRX Si CRX HF
Connector A / 6-pin (passenger side of cluster)
A1 Green/Red Emergency brake indicator C709 #6 C710 #5
A2 Blue/Red A wire is there but does nothing on instrument cluster
A3 Yellow/Green Water temperature gauge C709 #10 C709 #10
A4 Yellow/White Fuel level gauge C710 #3 C709 #11
A5 Green/White Low Fuel Indicator - Wire must be run from fuel tank after installing a 90-93 Integra fuel level sensor in the tank.
A6 Black Ground - Use either steering column mounting bolt if possible. C710 #8 unknown
Connector B / 8-pin (top center of cluster)
B1 Yellow/Red Speed Sensor Signal
B16 on 4G SiR ECU C710 #7 C709 #9
B2 Green/Yellow Right Turn Indicator C710 #1 C710 #1
B3 Black Ground - Use either steering column mounting bolt if possible. C710 #8 unknown
B4 Red/Blue High Beam Indicator C709 #11 C710 #3
B5 White/Blue Low Voltage Indicator C709 #2 C709 #3
B6 Black/Yellow Switched Power to Cluster C709 #3 C709 #4
B7 Blue/Yellow Overheated Catalytic Converter Indicator - -
B8 Green/Blue Left Turn Indicator C709 #12 C709 #12
Connector C / 10P (driver side of cluster)
C1 Green/Org Check Engine Indicator C709 #4 C709 #8
C2 Yellow/Red Oil Level/Pressure Indicator C709 #5 C710 #7
C3 Yellow Switched Power to Cluster C710 #2 unknown
C4
Unknown
empty
C5
Unknown
empty
C6
Unknown
empty
C7 Blue Tach Signal C709 #1 C709 #2
C8 Green/Blue empty
C9 Red/Black Dash Lighting C709 #9 C709 #7
C10 Red Dash Lighting C709 #8 C709 #6
Connector D (small connector that powers the CR-X drawing for doors/hatch open)
D1 White/Blue Illuminates all doors when ground (-) applied - -
D2 Green/Black Hatch Open Indicator ([-] wire to hatch switch) C710 #5 unknown
D3 Green/Red Driver Door Open Indicator ([-] wire to door switch) C709 #7 unknown
D4 Red/Black unknown - -
D5 - - - -
D6 - - - -
D7 Yellow unknown - -
D8 Green/Blue Passenger Door Open Indicator ([-] wire to door switch) You must run a new wire to
the passenger door switch
D9 Green/Red unknown - -
D10 Black/Yellow Switched Power to Cluster (connect with C3) C710 #2 unknown
daedreamah
12
Feb 23, 2008 06:02 PM
