My Car still goes to the left
Old May 23, 2007 | 04:26 PM
wallawee's Avatar
Default My Car still goes to the left
I drive a 96 integra with a b18c motor, w/ lsd tranny, and my car goes to the left when i mash on the gas. Recently had my hub bearing changed and my outer tie rod today. My car still goes to the left, anyone know what the problem still causing this? maybe my rack and pinion is out? can someone help me?
Old May 23, 2007 | 04:29 PM
wallawee's Avatar
Default Re: My Car still goes to the left (wallawee)
someone help me!
Old May 23, 2007 | 04:34 PM
wallawee's Avatar
reply please?
Old May 23, 2007 | 04:51 PM
civicstar's Avatar
did you get an alignment? well i had a problem with that when my rack and pinion whent out but it was making chattering noises
Old May 23, 2007 | 04:57 PM
wallawee's Avatar
Default Re: My Car still goes to the left (civicstar)
is a rack & pinion easy or hard to put in.
Old May 23, 2007 | 08:39 PM
wallawee's Avatar
Default Re: My Car still goes to the left (solbrothers)
yeah, all my wheels 15x6.5 around, tires 205/50/15. and no i didnt get an alighnment, my car is lowered on coil-overs, but i recently had the toe and caster adjusted.
Old May 23, 2007 | 08:40 PM
wallawee's Avatar
for some reason it feels like torque, but i figured its not it, since the lsd is there for a reason, so something in my steering is messed up.
Old May 23, 2007 | 08:55 PM
wallawee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">also just an FYI, but hondas don't have torque </TD></TR></TABLE>
torque steer, torque steer, torque steer
Old May 23, 2007 | 09:05 PM
civicstar's Avatar
rack and pinion is a Bitch to take out and put in, you have to go under the dash and unbolt the column, then unhook the power steering lines if you have them, unhook the tie rods, then unbolt the pinion itself and try to figure out a way to get it out of where it is, not much room but you can imagine
Old May 23, 2007 | 09:06 PM
civicstar's Avatar
also when i lowered my car and didnt get an alignment, it did the same thing (i also had a camber kit)
Old May 23, 2007 | 09:10 PM
wallawee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">also when i lowered my car and didnt get an alignment, it did the same thing (i also had a camber kit)</TD></TR></TABLE>
u know what, i forgot to explain why this steering situation started. One day i was driving on the freeway and was taking a turn pretty fast, and my steering locked up, i had force my wheel to unlock, and ever since my steering has gone to the left.
Old May 23, 2007 | 10:46 PM
civicstar's Avatar
well better get that rack and pinion changed then
Old May 24, 2007 | 10:03 AM
wallawee's Avatar
rack and pinion for sure then right?
y7turbo
Suspension & Brakes
Jan 22, 2009 08:45 PM
zenon8890
11
Jul 12, 2006 08:07 AM
Nerologic
Apr 29, 2004 06:51 PM
PhatHardy
May 14, 2003 06:54 PM
ZCPOWER
Jun 18, 2002 10:54 PM
