90 crx dx draining the hell out of my battery
i got a 90 crx dx and the problem is that the passenger door light does not turn off even when i tried to slam it shut it is still on does anyone have any idea what the problem is ????? is there a fuse or switch i can pull out
check the door sensors by the latch...see if you press it, does the dome light shut off...Sometimes the door gets misaligned and it's not making good contact.
Also check to make sure that the alternator wire isn't grounding out on the housing. Pull back the boot to the thick wire going to the alt. anc check to see if there is any contact.
flatblk
Nov 17, 2004 07:38 AM
