car is having problems starting....any suggestions?
The last couple of times that I have gone to start my car, it seems to be following some new pattern.
1. The car starts on the first crank....then slowly sputters down till it just dies.
2 - 6 ..... on these cranks, the car makes a weird sound, kinda like the starter isn't completely retracting after it cranks, and the car will not start. It acts like its going to, but it wont
Finally after a minute or so of that, it starts right up and runs perfect like normal.
Anybody got any ideas what this could be? Fuel pump going out maybe?
Thanks in advance
Thanks in advance
Sounds like its time for a tune up and valve adjustment. Could be any of the parts you'll replace, but I'd start with plugs, wires, dist cap & rotor, fuel filter, and a valve adjustment.
fuel filter....ah yes. I thought about that last night, but then I forgot.
Plugs and wires are new....valve adjustment has been done twice. I guess I could check it really quick again.
Any other suggestions?
What usdm cap and rotor can I use on my b16a1?
[Modified by hybridcrx, 12:27 AM 6/3/2002]
