Removing Alternator Belt
Old May 23, 2007 | 08:04 AM
LukieLuc's Avatar
Default Removing Alternator Belt
i have a 1995 honda prelude si w/ jdm h22a, i am trying to remove my alternator belt, to replace it with a minus A/C one, but i cant get the belt off the car, it gets stuck in between the pully and body of the car, how do i get the belt off and put on another? thanks
Old May 23, 2007 | 08:11 AM
Finest's Avatar
Default Re: Removing Alternator Belt (LukieLuc)
The space between the alternator pulley and frame is pretty tight. Just try to wiggle it around, turn it to the side or something to squeeze through. Otherwise, if you have a new one, just cut the old one and slip the new one from the topside then pull it through from the bottom.
Old May 23, 2007 | 01:59 PM
yOnKiNaToR's Avatar
Default Re: Removing Alternator Belt (Finest)
take the belt off the pulleys and then turn it sideways and slide it between the frame and the crank pulley. should come right out in a matter of seconds.
Old May 23, 2007 | 02:31 PM
LukieLuc's Avatar
Default Re: Removing Alternator Belt (yOnKiNaToR)
its wayyyyyy to tight it gets close to being stuck in between the pulley and the body of the car, do i force it through or is there an easyer way?
Old May 23, 2007 | 02:58 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">its wayyyyyy to tight it gets close to being stuck in between the pulley and the body of the car, do i force it through or is there an easyer way?</TD></TR></TABLE>
There should be enough room to pull it through. Just work with it and wiggle it around some.
Old May 23, 2007 | 09:00 PM
LukieLuc's Avatar
can i use a flat head screw driver or will it damage the new belt?
Old May 23, 2007 | 10:43 PM
LukieLuc's Avatar
Old May 23, 2007 | 10:59 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">????</TD></TR></TABLE>
Turn the belt sideways and pull it through dude. Lift or drop the alternator on the mounting bolt if you have to...
ubermoc
Feb 9, 2008 09:05 AM
tigueremalo
Jan 24, 2007 08:10 AM
dotay
Dec 30, 2006 01:35 PM
R6E6I6D
May 13, 2005 07:18 PM
siis2fast
Jun 26, 2003 09:36 AM
