oil gauges
i have a 94 ls w/ gsr swap, and i also have both a oil pressure and oil temp gauge, which one can i install with no extra parts needed?? thanks in advance H-T!!!!
If you just have the gauges and that is it then you will need parts. At the very least you will need electrical wires and connections and a tube (for mechanical oil pressure) that runs from a spot in the back of your block to the gauge itself.
Oil temperature gauges, new, come with a sensor that goes into your oilpan after you tap it.
-Rik
-Rik
i have just the gauges and have endless amount of wire to install them. i had got the used from my cousin and the gauges are not mechanical either. so what wire do i run the signal wire to then?? i didnt get any instructions just gauges!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlfrnce »</TD></TR><TR><TD CLASS="quote">i have just the gauges and have endless amount of wire to install them. i had got the used from my cousin and the gauges are not mechanical either. so what wire do i run the signal wire to then?? i didnt get any instructions just gauges!!</TD></TR></TABLE>
You need the sender for the oil pressure since it's elec.
What brand gauges are they even, I'd look on their site if they aren't cheapo.
well i have a faze A/F, and a faze oil pressure, then i have a srt oil temp from work made by autometer, i have the sending unit but no fittings but then if i can just use the pressure gauge then that is cool! i got both the fazes for $30 w/ the color chang button. If the sensor next to oil filter is oil pressure sensor, cant i just tap into that wire or no?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlfrnce »</TD></TR><TR><TD CLASS="quote">well i have a faze A/F, and a faze oil pressure, then i have a srt oil temp from work made by autometer, i have the sending unit but no fittings but then if i can just use the pressure gauge then that is cool! i got both the fazes for $30 w/ the color chang button. If the sensor next to oil filter is oil pressure sensor, cant i just tap into that wire or no?</TD></TR></TABLE>
If for the oil pressure gauge, you have the sending unit, it should look like just a large brass can.
So all you need is a brass T, with a male end to go into the block, female on the back for the stock oil light,
and I think it's a male end on the top for the sending unit.
ok then i will have to get the fittings this weekend, does any1 know what size i need to tell them to thread into block? and would i just splice in for the oil pressure sensor to function on the sensor next to oil filter??
drivers choice
Honda Civic (2001 - 2005)
Nov 10, 2006 06:12 AM
xx89civicracer89xx
May 17, 2006 07:20 PM
SPOON_BeIgHtEeNsEe
Mar 3, 2002 05:22 AM
