obdo to obd1
conversion harness , obd1 ecu either vtec or non vtec ecu i dont know much about zc
obd1 dizzy and coversion plug . you can keep you obd0 injectors as long as you dont remove your resistor box . rywire has just about everything you need.
http://www.rywire.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elrandeeto »</TD></TR><TR><TD CLASS="quote">conversion harness , obd1 ecu either vtec or non vtec ecu i dont know much about zc
http://www.rywire.com</TD></TR></TABLE>
https://honda-tech.com/zerothread/1508680
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axionm1k »</TD></TR><TR><TD CLASS="quote">hi im trying to find out what i need to convert obdo to obd1 i have a 90 hf crx with a sohc zc hf wire harness hf distributor si intake manifold 88 si ecu</TD></TR></TABLE>
Using the Search button in the upper right hand corner would be a start.
Pancho2193
Mar 2, 2013 06:35 AM
