intake battery destruction
Old May 23, 2007 | 01:37 AM
nickwil's Avatar
Default intake battery destruction
Hello HT!...first post ever, my name's Nick btw
Well I was driving home and I was taking my exit off the freeway, and suddenly I notice all my lights shut off. Tried putting Hazards - nope...so I was like "WTF!". I quickly pulled to the side and popped my hood. There was white smoke coming from under the hood and when I opened it, I saw that my negative battery cable ( the wire that is NOT next the the intake pipe) was fried to ****. The positive terminal had a rubber cover, which I thought would be enough protection, but I guess not. It only "started" to turn a little black.
edit: This part didnt go though...
Im going to buy new battery cables tomorrow, but what is the proper way to install them? I searched but I havent found any intruction. What others things do you think I'll have to replace? The white smoke was from the burning wires right?
Modified by nickwil at 9:28 AM 5/23/2007
Old May 23, 2007 | 02:57 AM
fin781's Avatar
Default Re: intake battery destruction (nickwil)
this want help but that is pretty gnarly. heh
Old May 23, 2007 | 06:49 AM
obd1_crx's Avatar
replace the ground wires under the hood. it should be the one comin off the battery, one runnin from the valve cover to the frame. you can run a couple extra if you want. i ran one from a bolt near the dizzy also to the battery so i ground the engine straight to the battery.
Old May 23, 2007 | 08:31 AM
nickwil's Avatar
He bought a new battery and neg. cable because it was tested that it couldnt hold a charge. He said he put it in this morning and it worked fine! He's just worried that something could be on the verge of being fried/crapped over from the shortage, like fuses n such. Should he worry?
Old May 23, 2007 | 11:14 AM
mvm's Avatar
mvm
Default Re: (nickwil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickwil &raquo;</TD></TR><TR><TD CLASS="quote">He's just worried that something could be on the verge of being fried/crapped over from the shortage, like fuses n such. Should he worry?</TD></TR></TABLE>
Its worth spending the 2 minutes to check in my opinion.
patrickstar
19
Aug 26, 2009 10:41 AM
patrickstar
Aug 24, 2009 12:25 PM
Bjorn20
15
Aug 11, 2005 10:19 PM
DJ_SaNdOz
Jun 5, 2003 08:18 AM
2trix
Sep 25, 2002 01:18 PM
