seat is loose
Do you normally drive with your seat all the way back? That is, when it slides forward the 1 cm, do you hear a click and the seat locks into place?
If so I wouldn't worry about it, it is just a little behind the last notch or latch or whatever locks the seat into place. Just get into the habit of scooting your butt forward a little when you get into the car to make sure it's locked in.
double check that the bolts are snuggd down all the way. the seat may be riding up on the bolts, not sliding forward, and you cant make the seat go up and forward at the same time in your driveway. grab the seat and give it a fre good jerks and see if it has any play. If the 4 bolts are tight, then remove the seat and check the slider assembly and check it for loose bolts/excessive wear
01celica_gts
Jan 17, 2017 12:31 AM
Cheesefries333
Nov 6, 2006 04:54 PM
mikestypeRR
Mar 23, 2005 03:23 PM
