ACL bearings
Old May 22, 2007 | 07:18 PM
crawlin's Avatar
Default ACL bearings
hey guys anybody ever run into any problems with the acl race bearings. i dropped my motor off to get built and my builder said the acl kit doesnt always work that kind of worries me considering who i bought them from said there is only one size for std and it wil definatly work.
any input opinions welcome
Old May 23, 2007 | 08:15 AM
Golden Eagle's Avatar
Default Re: ACL bearings (crawlin)
a Honda engine uses multiple size bearings so you can not just throw in some acl bearings and it will work for you you need to have the crank sized down to get the clearances you need
Old May 23, 2007 | 10:55 AM
ekb16's Avatar
i havent heard anything bad about them but i would go OEM..there are a few fully built k series running ACL bearings without any problems...
Old May 23, 2007 | 11:40 AM
Default Re: (ekb16)
no problems with acl at all you just need to size your crank to run them no big deal
Old May 23, 2007 | 02:38 PM
crawlin's Avatar
Default Re: (Golden Eagle)
is there a expensive charge for this? or will the builder just have it done?
Old May 23, 2007 | 02:51 PM
lovey408's Avatar
Default Re: (crawlin)
im in middle of a build as well. im usin acl bearings for my b16 and the machinest said that since im usin those i gotta get it line honed? sumthin like that dnt really recall wat exactly he used to explain it to me. but he said hes done this for others b4 and said there the best bearings!
Old May 23, 2007 | 03:05 PM
Default Re: (lovey408)
never let them line hone your block line bore maybe but there is a difference and all you need to do is have the crank sized line boring it for sizing is the wrong way to do it
Old May 23, 2007 | 03:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawlin &raquo;</TD></TR><TR><TD CLASS="quote">is there a expensive charge for this? or will the builder just have it done?</TD></TR></TABLE> your builder should be able to get you a price for it
Old May 23, 2007 | 03:08 PM
9200RPM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">never let them line hone your block line bore maybe but there is a difference and all you need to do is have the crank sized line boring it for sizing is the wrong way to do it </TD></TR></TABLE>
you mean line honing is the wrong way to do it..
Old May 23, 2007 | 03:37 PM
Default Re: (TurboB16aEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">
you mean line honing is the wrong way to do it..</TD></TR></TABLE>
no what i said, never line hone your block only line bore but line boring a block to get the right clearances is not the right way to do it ether line boring is if you don't have matching main caps or you block got out of line only
Old May 23, 2007 | 03:48 PM
lovey408's Avatar
wait so what shudnt i do? wat is the right/wrong way to do it?
Old May 23, 2007 | 04:05 PM
9200RPM's Avatar
Ok I see now...I misread what you wrote...
Old May 23, 2007 | 05:36 PM
crawlin's Avatar
yeah my builder was talking to me about all that i think its quite a bit of extra money to get it done will see if he calls me and tells me whats going on.
Old May 23, 2007 | 06:45 PM
4g hatch's Avatar
would a heavy micropollish take any amount off for clearances
Old May 24, 2007 | 07:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovey408 &raquo;</TD></TR><TR><TD CLASS="quote">wait so what shudnt i do? wat is the right/wrong way to do it? </TD></TR></TABLE> the proper way is to have your crank sized to get the Clarence you need
Charlie Moua
Jan 16, 2012 07:01 PM
sanjay2
Jun 14, 2010 07:21 AM
dustin_68f100
13
Jan 30, 2008 06:27 AM
D.Dappa
Jul 16, 2007 01:57 PM
