Gound wires Kit
Old May 22, 2007 | 07:17 PM
ctstylez's Avatar
Default Gound wires Kit
Does anyone know how to connect a ground wire kit? I try to install the other day and could not It keep doing weird things like the whole car would turn off or big sparks from wires would happen not cool.... Its a honda accord ex V6 Can someone please help me ??????
Old May 22, 2007 | 07:19 PM
TheMuffinMan's Avatar
He knows where you live!
lol it's not exactly difficult, i think most go from the negative battery terminal to different points on the car, I'm sure some go to a small box then grounded elsewhere, there should be no sparks anywhere
what the hell were you hooking it to?
Old May 22, 2007 | 07:32 PM
mnizzy's Avatar
Default Re: Gound wires Kit (ctstylez)
Are you talking about from the negative battery terminal to the chassis. If thats it the car shouldnt turn off because it shouldnt be turned on in the first place, and sparks shouldnt fly because you should disconnect the positive battery terminal before putting it on.
Old May 22, 2007 | 09:37 PM
Hawkze_2.3's Avatar
Just put the kit in the trash and step away from the car.
A ground wire kit does nothing...the only thing that may help you is cleaning/sanding the grounding point on your stock ground wires and replacing them with better quality & larger wire.
Old May 23, 2007 | 09:16 AM
ctstylez's Avatar
Default Re: (TheMuffinMan)
lol I disconnect the battery i start to put on the ground kit wires to the intake manifold ,left fender,left engine mount and the front of the frame,and the alternator the first time lol turned it on It was fine the second time i turn key to turn car on it just went out everything lol i look at fuses and they where fine disconnected the kit and the car was back lol sooo i try again this time i just took off the wire to the alternator car was fine but there was a big spark at the negative terminal ???? atfer about 1 minute i panic and took it off lol what iam tryn to understand is where are the right pionts they should be mounted on the chassis ??? Ooh and the second time when i went to turn the car on you can hear an electric clicking sound it was just one click it was like you can hear the electricy travel in the car lol is that normal ?? Am I suppose to Connect the orginall battery terminal to the rest Of the ground Kit LMAO can some one help ?
Modified by ctstylez at 1:36 PM 5/24/2007
Old May 24, 2007 | 03:27 PM
jlhansen's Avatar
You shouldn't have a single spark with the wire kit hooked to the NEGATIVE post and only to ground points on the engine/frame/body/peripherals/etc. You got a rogue connection somewhere or else a wire chafed and is touching something positive (highly unlikely). Most likely you put it to a hot terminal somewhere.
Old May 25, 2007 | 10:14 AM
Twixle's Avatar
ate my pixel
Default Re: (jlhansen)
Connect your ground wire kit to the negative battery terminal and then attach it wherever else it says to. I personally wouldn't risk keeping an ebay POS on my car if it started messing it up.
jsnm
10
Mar 3, 2007 08:03 AM
springfieldcivic
Jun 24, 2005 08:48 AM
Full Race A6
Audio / Security / Video
Jan 30, 2004 08:38 AM
slvrcivic97
15
Jul 21, 2003 02:03 PM
