b20 vtec build up!
Building a b20 vtec motor thought i might post some pictures up and keep you guys entertained during the process. Not looking to make a drag racing motor with 200+whp the only mods this motor is for road racing.
SO FAR
-block bore
-block hone
-block deck resurfaced
-big ends on rods rebuilt
-balanced LS crank
-balanced rods
-balanced 11.8:1 pistons
-balanced flywheel & plate
-shotpin rods
EDIT:
-ACL bearings
-Golden eagle vtec kit
-b16a head
-CTR dual valve springs/retainers
-CTR intake/exhaust cam(s)
-Spoon 70mm throttle body
-ITR intake manifold
-Spoon 4-1 header
Modified by 1.8L_allmotormilitia at 1:19 PM 7/18/2007
SO FAR
-block bore
-block hone
-balanced LS crank
-balanced rods
-shotpin rods
EDIT:
-ACL bearings
-b16a head
-Spoon 4-1 header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Imprezor »</TD></TR><TR><TD CLASS="quote">Wouldn't you happen to have a spare set of LS's crank and rods?
Thanks in advance.</TD></TR></TABLE>
No sorry. I only have gsr rods/ctr pistons spare and i might use them for another setup for someone else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShtNGit »</TD></TR><TR><TD CLASS="quote">Sweet block numbers you blocked out for a reason!!! lol What do you thnk bout a b20 w 11.2 forged pistons w scat rods holding up to a 75 shot?? </TD></TR></TABLE>
pmd
pmd
is there a reason why your running the LS crank instead of the B20 crank? I was thinking of doing a B20 vtec as well. I'd like to see how yours goes.
From: where i stunt SAND CANYON in Southern California
thanks guys.. we almost have everything rdy ! reason for going with a ls crank is because the b20 crank was messed up and b20 and ls cranks are the same and we had a ls crank rdy to go !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cypressink »</TD></TR><TR><TD CLASS="quote">is there a reason why your running the LS crank instead of the B20 crank? I was thinking of doing a B20 vtec as well. I'd like to see how yours goes.</TD></TR></TABLE>
yeah we already had the LS crank micro polished and balanced ready sitting in the basement. the b20 crank we had just how RED_90TEG said was real messed up so we just got rid of it.
itr1244
May 30, 2009 09:08 AM
