searched but no dice. has anyone tried the new sparks 84mm pistons?
just wondering if anyone has tried them. anyone KNOW anything about them? not interested in heresay. im about to do a basic 84.5x89mm b20V and im anxious to try these as they look a little more thought out than the traditional RS machine pistons.
* B A N N E D *
I have them, they're quality units. No problems with pin fitment, you also get full floating pins, w/ RS you don't. I've had RS ones and these are also much lighter.
No complaints here.
<FONT SIZE="3">SPARK RACING 84.5MM Pistons get
from me.</FONT>
No complaints here.
from me.</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tONE.steR »</TD></TR><TR><TD CLASS="quote">I have them, they're quality units. No problems with pin fitment, you also get full floating pins, w/ RS you don't. I've had RS ones and these are also much lighter.
No complaints here.
from me.</FONT></TD></TR></TABLE>
you get a full floating pin thru a stock rod with clips on each end?
No complaints here.
from me.</FONT></TD></TR></TABLE>you get a full floating pin thru a stock rod with clips on each end?
not to budge on the thread but are these pistons resonable cost wise? i would like to know more about them.. is there a site? i havent even looked yet because i just got on the thread.. these seem interesting. thanks
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDicktonesx »</TD></TR><TR><TD CLASS="quote">
you get a full floating pin thru a stock rod with clips on each end?</TD></TR></TABLE>
I haven't tried w/ a stock rod.
But they run clips on both ends vs. RS with no clips leaving you w/ no choice but stock rods.
They only offer 84.5mm right now they said 84/85mm will be a few months.
ok the wrist pin is oem sized so they will go on like an oem piston on a stock rod, and i guess you could use the pins as added security although is not nessecary.
The cir-clips would only need to be used if you were using after-market "floating pin" rods...
