slim fan question
Old May 22, 2007 | 04:17 PM
Prudz_lude's Avatar
Default slim fan question
ok so i bought a 12 inch slim fan to clear up the engine bay even more. its for the stock rad but just by putting it on the stock rad i can see that it does not come close to the holders. Has someone else installed this? can you shead some light on what to do?
I figure i should just get some metal pieces and drill holes in them, us bolts to the rad holes and bolts for the fan holes and tighten them up. Will this work fine or will it move around?
What about the wires? can i just cut the stock ones and attach to the new wires? do i need that plug in?
Old May 22, 2007 | 09:08 PM
Hawkze_2.3's Avatar
Default Re: slim fan question (Prudz_lude)
Your slim fan should come with install hardware, just use it to install the fan. Mine came with zip-tie-like things that go through the rad core and have a peice that snaps onto the other side and they work really well. You can also run very thin bolts through the core with a nut/washer on the tother side.
Old May 22, 2007 | 11:00 PM
SnlpeR's Avatar
i made some brackets for mine
bolts on to stock location
and uses the oem plug
Old May 23, 2007 | 08:49 AM
Prudz_lude's Avatar
Default Re: (SnlpeR)
well mine came with no hardware so i am a little upset. ill post pictures tonight when i get home so that you guys can see what i have to play with. Im probably just going to fab up some custom brackets since its not hard at all. The plug is what i am a little worried about. can someone answer the splicing question? is it alright to just cut the plugs off or the two wires and connect them to the new to wires without the plugs? its just wire, or is there something special about the plugs?
Old May 23, 2007 | 09:18 AM
Hawkze_2.3's Avatar
Default Re: (Prudz_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude &raquo;</TD></TR><TR><TD CLASS="quote"> The plug is what i am a little worried about. can someone answer the splicing question? is it alright to just cut the plugs off or the two wires and connect them to the new to wires without the plugs? its just wire, or is there something special about the plugs?</TD></TR></TABLE>
It's just wire...it's even color-coded for you! Just attach blue to blue and black to black.
Old May 23, 2007 | 09:26 AM
Prudz_lude's Avatar
Default Re: (Hawkze_2.3)
hahaha i know they are, i just spliced the wires for my speakers even though they had some plugs. just making sure its not going to expletive my car up. thanks. My car should be near finished in a few weeks so ill post all my pictures and progress then.
Old May 23, 2007 | 09:29 AM
Hawkze_2.3's Avatar
It's probably a good idea to splice before (or after...however you look at it) the plugs so you can still retain them.
Old May 23, 2007 | 10:21 AM
Prudz_lude's Avatar
yah i already thought of that. I dont want to expletive it up and have no back up plan
Old May 23, 2007 | 04:21 PM
cifer6425's Avatar
i made mine out of some alum. i had sitting around.
Old May 23, 2007 | 04:24 PM
Prudz_lude's Avatar
Default Re: (cifer6425)
Awesome, that is exactly what i just did today. I bought a piece of galvanized aluminum today and plan on cutting it up and bending it the same way. Looks great. I think i have the same fan. It has the same plastic mounting pieces.
namewasdallas
Dec 11, 2009 07:19 PM
joker4096
Jul 20, 2009 12:25 PM
wfocrx
Sep 20, 2007 08:17 AM
integraGSR213
Jul 22, 2005 07:14 PM
accordlove
Mar 9, 2005 07:13 AM
