96 gsr door lock actuator problems
Old May 22, 2007 | 03:14 PM
aimbot's Avatar
Default 96 gsr door lock actuator problems
Hi, i recently bought a gsr and none of the power locks work. Im about to check the actuators and i have read that the 6-p connector pins D and E are responsible for making the actuators turn on. the service manual that i was looking at said to put power on the D and ground on the E. The question i have is.. what kind of power? 12v? should i wire a battery to it and ground a wire and touch it on the pins. Im kind of a noob, but i think i did a good amount of research on it i just need a bit of direction to go about testing them. And btw, i need to buy a multimeter. Thanks!
Old May 22, 2007 | 03:59 PM
Blahblah718293's Avatar
Default Re: 96 gsr door lock actuator problems (aimbot)
what do you mean they dont work? do you hear any noise? do they try to engage but seem like they just dont have the power to do so? if you dont get any reaction in the motor at all try the fuse and check the wiring. if you hit the button and they look like they TRY to engage then try lubeing the motor.. there was a thread a few days ago about that. but i hear its a common problem.
Old May 22, 2007 | 05:50 PM
aimbot's Avatar
fuse is ok and the wiring looks good. It doesnt make any noise at all. I want to see if any 1 knew how to test the actuators and door lock controller thingy on the drivers side. thanks
Old May 23, 2007 | 08:08 AM
aimbot's Avatar
Anyone know how to test an actuator using the 6-p connector coming off of it?? OR the door lock module? THanks.
Old May 23, 2007 | 01:42 PM
aimbot's Avatar
anyone?
TravisCadello
Apr 6, 2009 06:05 PM
DriveSideWays
Mar 6, 2004 02:17 PM
h0ndacc0rd2o9
Feb 17, 2004 03:00 AM
EKhatchy
Audio / Security / Video
Jan 15, 2003 09:17 AM
