turbo timer mounting!
Old May 22, 2007 | 12:58 PM
4ghatch's Avatar
Default turbo timer mounting!
is this safe ?
My b spec 2 and greddy turbo timer in the center vent in the del sol
http://i18.photobucket.com/alb...1.jpg
will the heat get to hot for it? i dont need to break $500 worth of electronics like that
Old May 22, 2007 | 01:36 PM
Flashmn's Avatar
Default Re: turbo timer mounting! (4ghatch)
I dont know about heat, it does get quite hot when you have the heater on... but... that mounting method doesnt appeal to me
Old May 22, 2007 | 03:08 PM
4ghatch's Avatar
Default Re: turbo timer mounting! (Flashmn)
and where else in a del sol is there!! ? glove box and thats the only other spot
Old May 22, 2007 | 03:45 PM
Flashmn's Avatar
I'd personally put them in the center console somewhere.
Old May 25, 2007 | 07:58 AM
4ghatch's Avatar
and where in the pic would it fit ??
http://i18.photobucket.com/alb...3.jpg
thats the dash part with NO room at all and as for the center console arm rest area there is like 2 spots i tried out but theturbo timer and the profec are to deep for the low profile center console
Old May 25, 2007 | 09:23 AM
hitekper4mance's Avatar
double sided tape baby!! "Glue, I need Glue!" JUST KIDDING BRO!! If you utilize the vents, just make sure you seal off those vents in the back to "help" prevent the heat from getting to your electronics. Heat is heat and will get to it regardless, but by blocking off the vents, it will help a lot. Maybe install a small fan back there to help dissipate the heat as well.
1EK1EG
Northern California (Sales)
Aug 31, 2012 03:37 PM
ChRiS_p123
Jan 26, 2010 11:46 AM
nello a.
14
Feb 17, 2006 02:08 PM
