help on 90 HF front brakes
Old May 22, 2007 | 10:03 AM
ceyazzie's Avatar
Default help on 90 HF front brakes
which brake setup is good for my HF, 90'... and when i do the B16 swap.. would i need a the knuckles and hubs too do the change?? from the dx or si.. i seen thay are the same disk and pads.. and the ddrive axles r the same.. i need help... will the 90-93 integra parts fit??
Old May 22, 2007 | 10:20 AM
CRX Toad's Avatar
Default Re: help on 90 HF front brakes (ceyazzie)
https://honda-tech.com/zero...age=1
https://honda-tech.com/zerothread/1508680 <---FAQ
Please look at these two links. If this doesn't answer your question please use the search feature this has been covered to exhaustion.
Knuckles you will need either, DX, SI, EX or DA.
Thanks
90civicstdgold
May 17, 2009 08:36 PM
90crxdriver
Aug 19, 2008 06:19 PM
ceyazzie
24
Nov 25, 2007 05:54 AM
olddohc
May 8, 2007 07:13 PM
Si2See
14
Apr 25, 2005 12:02 PM
