DSM obd1 450cc Injectors...
Old May 22, 2007 | 09:34 AM
DA_JDM's Avatar
Default DSM obd1 450cc Injectors...
Ok i have started my motor with my OEM injectors for now...i have my dyno appointment in 10 days and now i have a big problem...the 450cc wont fit in the little hole where the injectors are I know when i put both the OEM and the DSM injectors i see that there is a different in size...but the guy that sold me those 450 told me it was plug&play that i just need to take out my OEM and replace them with the DSM...i really need to figure out what to do with this issue so if you think you can help me out feel free to post here or send me a PM
Thanks
Old May 22, 2007 | 11:52 AM
MR.johnson's Avatar
Default Re: DSM obd1 450cc Injectors... (DA_JDM)
cut the rubber oring down the middle.
Old May 22, 2007 | 12:08 PM
jkeno112's Avatar
Default Re: DSM obd1 450cc Injectors... (MR.johnson)
here you go homie. Hope its helps out
http://www.homemadeturbo.com/t....html
Old May 22, 2007 | 12:46 PM
jeffsciv23's Avatar
use some vasaline they'll slide right in when you tighten the bolts
Old Jun 20, 2007 | 01:39 PM
elusive123's Avatar
Default Re: (jeffsciv23)
I used grease ran them in with the rail and usually im against rigging things up i just didnt have a dremel so i went with the only way out at the time, so prime the car and see if you have leaks. This is basically temporary as it will reduce the life of the o-ring i would believe. jkeno gave you a perfect description i just bookmarked that sight thanks.
Old Jun 20, 2007 | 02:29 PM
kevinz's Avatar
Default Re: (elusive123)
You can go to any hardware store and buy a round file thays for a chain saw, thats what I've doon. under $5
itr1244
May 25, 2016 11:55 AM
djnikko
Aug 5, 2003 09:14 AM
SOFLSOL
Jul 21, 2003 06:20 PM
