94 Accord idle speed
Old May 22, 2007 | 08:32 AM
jcn168's Avatar
Default 94 Accord idle speed
I have a 94 accord, it runs about 100 k. What I have found is that the idel speed is quite low, about 500 rpm. I think it is low because when it is warm and on "P", I can feel the vibration on the driving wheel.
I used to drive a collora, it had similar problem. A mechanic worked on it. Actually, he did not fix the problem. Following instruction from a book, I fixed the problem by myself. So, I did not trust the mechanic too much. Sure, a mechanic from Honda dealer may be different.
Could any one help me with accord idle problem? Is there any website for this so that I can do it myself step-by-step?
Thank you very much!!
Old May 22, 2007 | 08:42 AM
Eddiebx's Avatar
theres a slotted screw on the side of the TB, it is brass, u can turn that in and out to adjst the idle speed to your liking.
Old May 22, 2007 | 09:59 AM
jcn168's Avatar
Thanks.
Do you have any picture about the slotted screw, what is TB? I am sorry, I do not know many of those terms.
Again, thank you very much.
Old May 22, 2007 | 10:21 AM
Eddiebx's Avatar
i dont have a picture, but the TB is the throttle body. the rubber intake are connects to it, and u will see the brass screw on the side of it.
Old May 22, 2007 | 12:14 PM
hondadude's Avatar
Default Re: (jcn168)
In the picture below you can see the Idle Air Adjustment screw at the 11'o'clock position. Grey sealer on it, counterclockwise to increase air and RPM.
You might also consider cleaning out the throttle plate area with a toothbrush and carb cleaner, possibly the screen at the IACV is plugged up as well.
Here is a link to help you some more;
https://honda-tech.com/zerothread/1844067
2002dodge
Feb 17, 2010 09:52 AM
EgK2o09
Sep 16, 2009 06:36 PM
DanielH33
Feb 21, 2009 06:59 AM
sorce_money
Dec 19, 2004 10:32 AM
khny83
Jan 20, 2003 08:23 AM
