Lets here your predictions.
On Saturday im gonna go get my car tuned at raceline in Ohio . This is what I got.
95 GSR turbod T3-T4
3inch down pipe and exhaust
550 injector
10lbs of boost
255 fuel pump
tubular header
it has valves and springs
That is all I can think of but im sure im forgetting somethimg.
95 GSR turbod T3-T4
550 injector
10lbs of boost
255 fuel pump
tubular header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CARMA_626 »</TD></TR><TR><TD CLASS="quote">I predict a loud bang...then clunk, clunk, clunk, drip, drip
hahahaha!
My prediction is the same, don't take any short cuts bro...If you are going turbo, do it right the first time around...
</TD></TR></TABLE>hahahaha!
what short cuts . Its been running on afc hack for a year . Now im gonna put my hondata on. Im not one of those rich **** that there mommy and daddy buy there parts I work for mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones »</TD></TR><TR><TD CLASS="quote">
hahahaha!
Yup, I agree.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracer13 »</TD></TR><TR><TD CLASS="quote"> ...That is all I can think of but im sure im forgetting somethimg.</TD></TR></TABLE>
Yes, I think you're forgetting something too; like rods, rod bolts, lower compression pistions, rings, head gasket, head work...
hahahaha!
</TD></TR></TABLE>Yup, I agree.
mid 200's for like 4 months
itll be fun while it lasts tho. u shoudl be good as long as u dont start boostin it more. id say if u want anything more than ten yur gonna wanna make the motor stronger
i put you at mid 200's depending how good of a tune you are getting. you can run 10 pounds all day long on a good tune. forged internals wouldnt hurt tho if you wanna go bigger and more boost.
dont let the haters get to ya.
well i believe the dyno is a dynopack. i plan to run a t3/t4 with or below a .58 trim at no more than 9 psi. i found a buddy club headgasket that will lower my compression to about 9:1 too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be18see1 »</TD></TR><TR><TD CLASS="quote">well i believe the dyno is a dynopack. i plan to run a t3/t4 with or below a .58 trim at no more than 9 psi. i found a buddy club headgasket that will lower my compression to about 9:1 too.</TD></TR></TABLE>
Screw the head gasket. If your tuner is good he'll have NO problems with 10:1. You can see my setup in my sig, but not all that different to yours. I'm not to familiar with that dyno...but you'll probably put down 260 to 280. If it were a dynojet I would say close to 300.
Honestly though, a number is just that, a number. You should be more concerned with just getting a good tune so the motor will last a long time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracer13 »</TD></TR><TR><TD CLASS="quote">That is all I can think of but im sure im forgetting somethimg.</TD></TR></TABLE>
You forgot to open a thread to new technical discussion.
Only the dyno will be able to tell you what your setup is capable of... I am sure there are a lot of similar setups here on HT that have posted their results; by using the search feature, access to this wealth of information is at your finger tips. Best of luck with the tune and dyno... and Happy Searching.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracer13 »</TD></TR><TR><TD CLASS="quote">what short cuts . Its been running on afc hack for a year . Now im gonna put my hondata on. Im not one of those rich **** that there mommy and daddy buy there parts I work for mine. </TD></TR></TABLE>
First of all I am not rich, I also work for a living...I don't live with my mommy guy..And 2nd just trying to help you, from blowing your engine, because I figured you don't have much cash...If you are trying to run it the way are saying...and to answer your question...I would say 240 or so, depending on the size of your snail, and how much you'll be boosting...Let's not get smart with people who are trying to help!
