no start/stock 91 crx with a 1.5, anyone help?
Old May 22, 2007 | 07:14 AM
chaseajcc's Avatar
Default no start/stock 91 crx with a 1.5, anyone help?
i was driving and car stalled in mid flight, i checked spark, compression and timing, all checked out good. however when i put a fuel gauge inline with the fuel system, I observed the fuel pressure Gauge doing something abnormal, when i start the engine. the gauge jumps to 40psi(normal) and within 1-2 seconds it goes down to 0psi....im thinking the pintal on the injector is stuck open , i do have the dual setup not the 4-injector setup...can anyone help me out?
Old May 22, 2007 | 07:15 AM
mvm's Avatar
mvm
Check your fuel pump.
Old May 22, 2007 | 07:21 AM
chaseajcc's Avatar
Default Re: (mvm)
i hear kicking on, but still maybe bad?
Old May 22, 2007 | 07:26 AM
thenick's Avatar
Default Re: (chaseajcc)
Summer season is around the corner -- I suggest popping open the main relay and checking out that solder connections.
Old May 22, 2007 | 08:11 AM
chaseajcc's Avatar
i will look into that relay...
Schayward420
Oct 25, 2009 06:19 PM
allmotor2.1
Nov 24, 2007 04:52 AM
97eksoldier
May 23, 2007 09:39 PM
fracas
26
Dec 11, 2005 08:59 AM
crix351c
Jun 18, 2005 01:33 PM
