What all swaps over from a 94 gsr to a delsol?
Old May 22, 2007 | 12:00 AM
4drintegragsr's Avatar
Default What all swaps over from a 94 gsr to a delsol?
First time post please help. Ive been searching and couldnt find my anwser. i currently own 92 4dr gsr and im looking 2 buy a del sol. i kno the b18c will work in the sol but i was wondering if i could swap the entire suspension and brakes outa the integra to the delsol. and how hard this would be... worth the work? and what all was interchangeable between the del sol and the integra.. is it the same as the 92-95 hatch... thanks
Old May 22, 2007 | 01:08 AM
BlueIntegraBoy's Avatar
Default Re: What all swaps over from a 94 gsr to a delsol? (4drintegragsr)
There wasn't a 92 GSR sedan (I assume you meant 94 like the title). You can swap over the whole suspension (brakes included). It is really easy and worth it. However, you will need to buy Del Sol Si or Del Sol VTEC ebrake cables as the Integra cables are too long.
Old May 22, 2007 | 01:46 AM
smileycvc's Avatar
Default Re: What all swaps over from a 94 gsr to a delsol? (BlueIntegraBoy)
the motor, axles, seats, steering wheel, suspension, brakes, drivers side motor mount, radiator, damn near everything so just pull everything off and swap it. change out the master cylinder and prop valve too.
Old May 28, 2007 | 09:43 PM
Thanks for the info... i thought everything would work... yah def a type i own a 92 ls as well not new to the hondas juss never had 2 swap b4 ive always owned an integra
marecco
Sep 9, 2006 01:09 PM
94_del_sol
Nov 17, 2004 05:32 PM
Daikirai
Sep 29, 2003 06:13 PM
Sideshow9090
Jun 27, 2002 11:43 PM
KooK
10
May 4, 2002 09:16 PM
