help:mini me: spark, fuel, etc, but no start....
engine: d16a6 (90 crx si)
head: d16z6
got everything swapped over nnicely, plugged in etc, but ran into trouble when the car would crank but not start. Wouldnt even sputter or nothing. just cranking.
Didnt do an obd0 to obd1 conversion. doing that later. Also using the stock crx ecu, and vtec isnt hooked up at all. Not going to be using vtec till next week or so.
tried everything i could for getting the crx to start. The plugs from the dizzy are right, even reversed them incase. crank but nothing else. not even a sputter. There is power to the plugs, and sparks from the spark plugs. Fuel is making it to the spark plugs every time aswel. The car is using the stock (90 crx si) starter and fuel system. Only things added were the z6 head with z6 intake manifold.
Car has a check engine code of 10. I forgot offhand what it was, but it should not have anything to do with preventing the car from starting.
any suggestions?
head: d16z6
any suggestions?
Is the timing right? Is both the head and bottom lined up right at TDC? Are you sure the injectors are getting fuel to them?
I believe code 10 is the air temp sensor.
tr3nt133
Nov 5, 2014 03:50 PM
USDM 4G VTEC
17
Jun 25, 2002 06:19 PM
USDM 4G VTEC
Jun 25, 2002 01:22 AM
