Starter Wire Color
I am looking for the color of the starter wire from the ignition that is ONLY 12 volts when the ignition is in the cranking position. If you can tell me the color and what harness it is in i would appreciate it alot. This is for a 2001 GSR
- Chris
- Chris
it is a black wire with white line if you go under the dash it should be coming from the ign. good luck go on
www.the12volt.com
www.the12volt.com
ShadowBar
Jan 26, 2009 05:32 AM
99delsol
Sep 13, 2006 09:09 PM
