ECL at 3000rpm / 40mph
Old May 21, 2007 | 08:59 PM
deroblim's Avatar
Default ECL at 3000rpm / 40mph
check light comes on only at 3000rpm and 40mph. when i shut down and restart, it goes off. recently had a head (& timing belt and other stuff)change due to overheating. realised pick up is sluggish too. and white smoke out of the exhaust when start engine. what could be the problem? HELP
Old May 21, 2007 | 09:01 PM
street_ride14's Avatar
Default Re: ECL at 3000rpm / 40mph (deroblim)
Jump the service connector and locate the Check Engine light problem.
And go from there.
Old May 21, 2007 | 09:02 PM
nonvteclude's Avatar
who did the gasket change? was the head and block checked for any warpage? was a compression test done before and after head change? are you loosing oil quickly?
Old May 21, 2007 | 09:07 PM
Default Re: ECL at 3000rpm / 40mph (nonvteclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">who did the gasket change? was the head and block checked for any warpage? was a compression test done before and after head change? are you loosing oil quickly?</TD></TR></TABLE>
What ?? It's more likely a bad o2 sensor affecting air/fuel ratios. What does oil have to do with running sluggish ??
Old May 21, 2007 | 09:08 PM
Default Re: ECL at 3000rpm / 40mph (street_ride14)
holy hell i read that wrong i thought i read blue smoke. oops my bad.
Old May 21, 2007 | 09:14 PM
deroblim's Avatar
tks guys... checked the connector.... gave me a 23 knock sensor. but if realy is the knock sensor faulty, shouldnt it comes on when i start and nt jus appear after driving for a while?
Old May 21, 2007 | 09:20 PM
BlownH23a
Guest
Posts: n/a
check your freggin map sensor, that happened to me about year and a half ago...check the map sensor vac lines especially.
Red-Rag-B18
Aug 23, 2010 05:33 PM
jlopez88
May 14, 2008 07:23 PM
ac_attak
Jan 4, 2007 05:11 PM
P@@RB@Y
Jan 20, 2006 01:19 PM
Silvteg95
Aug 8, 2005 04:24 PM
