Wiring diagram
Old May 21, 2007 | 06:08 PM
BAShibby21's Avatar
Default Wiring diagram
Can anyone help me out with a link to somewhere to get a wiring diagram for a PR3 OBD0. Or a 91 CRX HF to b16a PR3 diagram?
Old May 21, 2007 | 09:41 PM
EF_LSVtec's Avatar
Default Re: Wiring diagram (BAShibby21)
Can you reword? What exactly are you trying to do? Do you need PR3 ecu pinout?
http://www.boosted.org/obd0.php?page=obd0
Old May 22, 2007 | 09:34 AM
BAShibby21's Avatar
Default Re: Wiring diagram (EF_LSVtec)
Just like a wire color diagram cause I had someone rewire it and I think they hooked some same color wires to the the wrong other wire and its throwing code 6 now.
Old May 22, 2007 | 09:40 AM
ludesrv's Avatar
Well you could of just kept the stock harness and plugged in the ECU. Would of only thrown code 21 and code 22, both are vtec codes. You would of only needed to add a few wires too. Depends on the ecu, but I think obd0 only needs the 12v from a8 to vtec solenoid, and vtec oil pressure going somewhere else. on the ecu.
Sorry if I'm unclear, I'm sick as hell and trying to help my best.
ufakeit
Sep 7, 2009 05:39 PM
Paul26
Mar 28, 2009 12:30 AM
triceeetrev
Sep 10, 2003 01:13 PM
