Problems with gsr swap HELP!
Old May 21, 2007 | 06:07 PM
hndata9600's Avatar
Default Problems with gsr swap HELP!
Ok i recently bought and swapped a 99obd2 gsr motor and put it in my 93 civic using and obd1 gsr harness and obd1 STOCK ecu.
Here are the problems I am having.
1. I do not know how to hook up the IAB box (keep in mind I have a aftermarket fpr on the fuel rail).
2. I have a plug near both of the strut towers that dont connect to anyhting. One on th drivers side is green and is closer to the IM than the strut tower but you get the point.
3. Now for some reason on my bone stock obd1 gsr ecu vtec is kicking in around 42-4500 and i feel like i have no power compared to my obd1 gsr motor i had previously and this new motor has headwork so it shoudl feel as good if not better.
4. Other than that the car is driving excellent....oh and i have a 94gsr tranny on the new 99 motor doubt that matters though..
5.I have a tuned ecu thats tuned for a obd1 gsr boosted on 9lbs...can i use that ecu on my stock motor if not why? what problems will it cause other than maxing out the injectors?
thanks!
Old May 21, 2007 | 06:38 PM
4g hatch's Avatar
what up im right on the other side of the moutain. your fuel and timing maps are gonna be way different for n/a.im not familar with gsr's is the iab box for the secondary butterfies.
Old May 21, 2007 | 07:11 PM
hndata9600's Avatar
yeah thats what i figured...so i probably dont want to use the turbo ecu...
Old May 21, 2007 | 07:30 PM
4g hatch's Avatar
deffinatly not.
Old May 22, 2007 | 04:25 AM
hndata9600's Avatar
nobody knows whats going on?
Old May 22, 2007 | 05:55 AM
JimBlake's Avatar
Default Re: (hndata9600)
Got the IAB control valve too?
Here's a vacuum line diagram.
It doesn't really matter what FPR you have. Just need to supply that canister (#7) with vacuum. Use a check valve (#4). The ECU will control the IAB solenoid (#6) to open & close them when they're needed.
Normally a boosted engine won't use the 2-stage intake manifold, so your turbo-programmed ECU is probably not right for this.
If your secondaries are open all the time, that would explain the lack of power at low rpm.
Old May 22, 2007 | 06:06 AM
4g hatch's Avatar
thats a good diagram
Old May 22, 2007 | 05:28 PM
hndata9600's Avatar
Ok now that tack is all bouncy while im driving it and its feels very weak for a gsr anyone have any ideas?
Old May 23, 2007 | 06:22 AM
4g hatch's Avatar
if the tach does crazy things then either the coil or the dizzy is getting ready to take a crap. try another good dizzy from a friend and see if it goes away
Old May 23, 2007 | 09:43 AM
jdb2527's Avatar
Default Re: (4g hatch)
bump for cville!
Old May 23, 2007 | 11:07 AM
4g hatch's Avatar
double bump
luvmihatch
May 28, 2012 09:22 AM
92_VX_EG
Mid-Atlantic (Sales)
Aug 11, 2007 01:56 AM
