Which tein hood damper
I saw a recent pic of rywire's crx with tein hood dampers. I google searched and couldn't find a product specifically for a crx. Anyone know which model number I should buy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Fly SI »</TD></TR><TR><TD CLASS="quote">eg hatch</TD></TR></TABLE>
x2 and then there's minor modification to make it work, but it's pretty straighforward.
Figure it out. Buy EG hatch dampers, install em on your EF, never drop your hood on your head again
you can try the passwordjdm ones.!!!!! direct fit for the EF with the right bracket.!!
i'm a dealer of password..but that's not the point......they have a valve pressure on them so you can adjust them if you have a CF hood...so they won't crack your hood like the other ones....
x2 since I'll be using my vis hood.
Went to the site and found it immediately. Item # PSWHDBLKEF9
Modified by speedKILLS at 7:49 AM 5/22/2007
so how do you fit them? do they come with everything required to fit these, or do you need to make a bracket or something?
heres the link to them for the EF crx people http://passwordjdm.com/Passwor....aspx
doesn anyone have any pics od these fitted to a crx??
with the password ones,you unboult the upper bolt from the hood,remove the middle one of the fender.slap the supplied bracket at the hood,re-put the bolts..and voila!! :D
SupaMonkey
Feb 17, 2011 10:31 AM
