Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How to take apart a drivers side seat 2002 civic coupe
Old May 21, 2007 | 04:21 PM
sunniskyee's Avatar
Default How to take apart a drivers side seat 2002 civic coupe
Hello, i am new to this site, and i have looked everywhere for this, but i am reupholstering my car with katzkin leather and i ran into a speed bump with the drivers side door,
first: cannot figure out how to take the plastic piece that has the hight adjustment on it off, i talked to honda and they told me it should just be clips, but with the seat adjustment ****, wouldnt there be a bolt that goes to the frame to lift it up and down? and second: how do you separate the top (backrest) from the seat part?
Also, i took the door panel off to put the leather on the door panel, but it seems to be all one piece and machine pressed in, any tips on how to pull the cloth off if it is glued and pressed in and install the leather to make it look decent?
Thanks so much
Modified by sunniskyee at 7:49 PM 5/21/2007
Old May 21, 2007 | 04:58 PM
Shintakun's Avatar
Default Re: How to take apart a drivers side seat 2002 civic coupe (sunniskyee)
those questions seem kind of low level. but im sure just by looking at it you could figure it out. look at the bolts and what they hold
memorize or take pictures while your doing it to remember how to put it back together.
good luck maybe if you get through it you can put up a DIY
sportspassion13
Aug 5, 2013 01:49 PM
accord95vtec
Acura TL, RL & ZDX
Oct 25, 2009 04:42 PM
91whiteREX
Sep 16, 2008 05:55 PM
works909
Jun 6, 2005 08:32 PM
