2.5 in exhaust vs 60 mm
Old May 21, 2007 | 04:11 PM
mr2turbo007's Avatar
Default 2.5 in exhaust vs 60 mm
What would the back pressure/ performance difference between 2.5 and 60 mm.
2.5 piping manderal bent
magnaflow muffler
22 in resnator
or apexi world sport 60 mm
how much of increase in hp and torque would i pick up going to the 2.5 in route.
82mm b18c1
weisco pistions
11.8-12.0 compression
crower maxi light rods
acl bearings
type r oil pump
b16 head
pnp that i can see my self in the exhaust ports lol
skunk 2 pro 1 cams
valve springs n retainers
flat top valves
skunk 2 im ported 70 mm
70 mm tb
Smsp header
should dyno around 210 whp
how much will the apexi hold me back because the fitment and sounds is alot better than a custom 2.5 in system
Thanks
Old May 21, 2007 | 04:36 PM
Timmay's Avatar
Default Re: 2.5 in exhaust vs 60 mm (mr2turbo007)
well 60mm is like 2.3.. so going ot 2.5 may not add a ton but it still might pick up a little bit
Old May 21, 2007 | 05:26 PM
Default Re: 2.5 in exhaust vs 60 mm (Timmay)
the other part of this equation is the apexi exhaust has a baffled muffler vs. a straight through with the magnaflow. so how much whp will the baffled muffler hold back as well. if it under 5whp it no big deal
Old May 21, 2007 | 06:16 PM
DA_JDM's Avatar
buy a 60mm straight thru...its gonna make more power then a 2.5" non-straight exhaust!!! I love my RS*R GTII
Old May 21, 2007 | 06:58 PM
chris2000's Avatar
Default Re: 2.5 in exhaust vs 60 mm (DA_JDM)
i'm running a 60mm straight tru race system with a small center muffler. Loud like hell but made good numbers for a B18C. I'm looking at going 70mm skunk2 race exhaust and that will be about 2.75" which i hope is going to flow better and a little quieter than my current setup.
Old May 21, 2007 | 06:59 PM
SMSP's Avatar
Higher the hp the greater the difference.
2.5 tubing has a 12% increase in internal area versus 60mm tubing. THe parts you listed are straight through pieces so they will flow better than a chambered muffler but will be louder.
Here's a test I did with my old car (D16) which had a 60mm B Pipe. https://honda-tech.com/zerothread?id=1739065
Old May 21, 2007 | 09:15 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">buy a 60mm straight thru...its gonna make more power then a 2.5" non-straight exhaust!!! I love my RS*R GTII </TD></TR></TABLE>
What about a 2.5" straight through exhaust?
Old May 22, 2007 | 03:58 AM
Default Re: 2.5 in exhaust vs 60 mm (SMSP)
Dave ill tow my car to ur place and you put my exhaust together because i cant get it to fit right. The over the axle piece and the muffler do not want to fix together at all.
I live in Md
Old May 22, 2007 | 05:56 PM
ketchup!
Jul 21, 2008 08:46 AM
blackv6
Jul 12, 2006 02:20 AM
ken-e
Nov 30, 2004 01:51 PM
BolivianDc2
Sep 5, 2003 06:23 AM
1badITR
Mar 23, 2002 10:14 AM
