90 integ GS b20 auto swap?
Old May 21, 2007 | 02:41 PM
usdm_ED7's Avatar
Default 90 integ GS b20 auto swap?
hey whats up guys, well since my beater is bout to take a dump on the motor and tranny i decided to go with a b20 swap since its cheaper then a ls. i am just going to rebuild the tranny also. i was wondering if i can use the same ECU and if all the parts like AC and all that stuff swap right over? any help is appreciated! thanks
jaysin
Modified by usdm_ED7 at 11:53 PM 5/21/2007
Old May 21, 2007 | 04:28 PM
usdm_ED7's Avatar
Default Re: 90 integ GS b20 auto swap? (usdm_ED7)
im sure someone out there knows. ive been told that i need to swap out the ECU, but other says i dont. any help is really appreciated! thanks
Old May 21, 2007 | 04:32 PM
turbo93da's Avatar
use all factory parts from the 90
and you should have no problems
the computer is fine just make sure you run a good heat range plug
josh
Old May 21, 2007 | 05:39 PM
usdm_ED7's Avatar
Default Re: 90 integ GS b20 auto swap? (turbo93da)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo93da &raquo;</TD></TR><TR><TD CLASS="quote">use all factory parts from the 90
josh</TD></TR></TABLE>
thanks...
ive been reading that i need to relocate the oil temp sensor and wire up the coolent temp sensor? is this true? i thought it was just a straight swap, let me know thanks again guys
Old May 22, 2007 | 02:26 PM
turbo93da's Avatar
yes that is correct
thcap1
Apr 6, 2008 06:28 PM
cmorris87
Mar 9, 2008 09:17 PM
sdgenxr
Mar 26, 2004 03:10 PM
