Honda S2000 Honda S2000
Will these fit?
Old May 21, 2007 | 02:33 PM
modifyORdie's Avatar
Default Will these fit?
I searched for the wheel specs on an 02, but all i could find is that 18.8 fits...is the lug pattern 5x114? Anyways I wanted these rims http://www.axiswheels.com/whee....html and I wanted to know if they would fit...also do you have to go staggered?
Old May 21, 2007 | 02:43 PM
LAS2K's Avatar
Default Re: Will these fit? (modifyORdie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modifyORdie &raquo;</TD></TR><TR><TD CLASS="quote">I searched for the wheel specs on an 02, but all i could find is that 18.8 fits...is the lug pattern 5x114? Anyways I wanted these rims http://www.axiswheels.com/whee....html and I wanted to know if they would fit...also do you have to go staggered?</TD></TR></TABLE>
5x114
yes please stagger.
Old May 21, 2007 | 03:05 PM
Default Re: Will these fit? (LAS2K)
do i tell them that when i order...or do they automatically know when i tell them what car it goes on?...and if i go with 18's...i go with 18.8 on front & back?
Old May 21, 2007 | 06:14 PM
anyone know??
Old May 21, 2007 | 06:46 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
yes it will work but i would not limit myself to 8's in the rear
Old May 21, 2007 | 07:10 PM
Default Re: Will these fit? (S@nt0s)
thats what i was trying to figure out what sizes...apparently there are more than what were listed on that page...will 18.9's fit in the back? we were thinking the 90 mm lip 18.8 in front and 18.9 120 mm lip in rear.....didnt know if that would work or not
Old May 21, 2007 | 07:11 PM
silentdancer's Avatar
it depends on offset. not the amount of lip
Old May 21, 2007 | 07:34 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
thats what im saying the only one that will work is the x8 +40
Old May 21, 2007 | 07:38 PM
Default Re: Will these fit? (silentdancer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdancer &raquo;</TD></TR><TR><TD CLASS="quote">it depends on offset. not the amount of lip</TD></TR></TABLE>
yeah i know what...i was just saying there were different sized lips for each offset
Old May 21, 2007 | 07:39 PM
m R g S r's Avatar
i think those wheels look real good...but only in a lowww offset with a huge lip...too bad they won't fit correctly with the huge lip
Old May 22, 2007 | 06:57 AM
Default Re: Will these fit? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">i think those wheels look real good...but only in a lowww offset with a huge lip...too bad they won't fit correctly with the huge lip</TD></TR></TABLE>
thats what i was also wondering....if i could go with the 120 mm lip or not...guess ill just call them and ask
Old May 22, 2007 | 08:32 AM
Import_Fan's Avatar
I'd say theres a snowball's chance in hell that you'll be able to get anything with a 120mm lip on an S to be flush with the body unless you have some crazy flares. The offset necessary to get that effect is just too low. If you buy them, your wheels WILL stick out. The higher the offset, the better.
Old May 22, 2007 | 08:37 AM
Default Re: Will these fit? (Import_Fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Fan &raquo;</TD></TR><TR><TD CLASS="quote">I'd say theres a snowball's chance in hell that you'll be able to get anything with a 120mm lip on an S to be flush with the body unless you have some crazy flares. The offset necessary to get that effect is just too low. If you buy them, your wheels WILL stick out. The higher the offset, the better.</TD></TR></TABLE>
the site showing:
rear standard 50 mm front and 110 mm back
rear extreme 80 mm front and 110 mm back
which doesnt make since because on the main part of the site, the only sizes they are showing are 60, 90, and 120 mm......but 50 mmm just doesnt seem deep enough for the front...so im calling them right now to see if the extreme would fit without sticking out....also i'm still confused...if i go with 18's what offset do i use for front and back? All thats showing on the site is 18x8 and 18x9
Old May 22, 2007 | 09:14 AM
OK i just got off the phone and the dude said to run:
Front: 18x8 60mm
Rear: 18x8 90 mm
he said he had to grind the rear calipers just a bit to get it to fit though
Old May 22, 2007 | 09:16 AM
Mr. Projekt's Avatar
* B A N N E D *
So what's the point of putting on these wheels?
I see a +40 and a +20 offset.
Old May 22, 2007 | 09:19 AM
Default Re: Will these fit? (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">So what's the point of putting on these wheels?
I see a +40 and a +20 offset. </TD></TR></TABLE>
whats the point of putting on any wheels? he said to run a 40 offset
or should i run the 18.9's on the back? ?? this has got me completely confused...im so used to fwd cars where all you need to know is tire size and bolt pattern T_T;
Old May 22, 2007 | 09:22 AM
* B A N N E D *
or should i run the 18.9's on the back? ?? this has got me completely confused...im so used to fwd cars where all you need to know is tire size and bolt pattern T_T;</TD></TR></TABLE>
Should do some research before you start throwing random wheels on. Key words "STAGGERED" and "HIGH OFFSET" should ring bells.
Old May 22, 2007 | 09:23 AM
i know which is why im doing this...i dont eve n have the money to buy them right now but i want to make sure they fit...i think i found out though look:
http://www.buywheelstoday.com/...=2643
Old May 22, 2007 | 09:28 AM
* B A N N E D *
Oh I see... it's one of those threads... have fun!
Old May 22, 2007 | 09:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Oh I see... it's one of those threads... have fun! </TD></TR></TABLE>
one of what threads?
Old May 22, 2007 | 10:33 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
one of what threads?</TD></TR></TABLE>
yes a wish i, should i, could i type.....
you could have all your questioned answered instead of having the same question asked every few days on what wheels fit the S2K... depending on wheel width you can go anywhere from +35 to +70....
and as i stated above
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote"> only one that will work is the x8 +40</TD></TR></TABLE>
Old May 22, 2007 | 10:36 AM
well jesus christ excuse me, but i would like to make sure something fits before i put down $1200...and btw...if i really wanted the wheels exactly at this moment i could buy them. however there are more important things to pay for at the moment, and i'm not planning on getting these until next month. kinda hard to do research on the product if you have to "buy" them right away to satisfy your "wish i could i" crap.
Old May 22, 2007 | 10:42 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
a few mins and you can find out what offsets would work on the S2K... the S2K uses what i would say a FWD offset basis....
i think i know a think or 2 about offsets i have had +30's on mine at 1 point jsut to know.....
so again look around and you will find your answers..
i wouldnt go with those wheels anyways because you are limiting yourself to a 8in rear.... also they dont look like at all..
Old May 22, 2007 | 10:45 AM
i originally searched this forum before i even posted this but thanks for your help anyways
Old May 22, 2007 | 11:41 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Your search for offset returned 26 results.
heres a few...... now who searched?
https://honda-tech.com/zerothread?id=1469231
https://honda-tech.com/zerothread?id=1986067
https://honda-tech.com/zerothread?id=1949809
https://honda-tech.com/zerothread?id=1876541
https://honda-tech.com/zerothread?id=1845974
https://honda-tech.com/zerothread?id=1656862
https://honda-tech.com/zerothread?id=1414891
https://honda-tech.com/zerothread?id=1360651
