Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
__ Replacing Fuel Pump on '02 Civic __
Old May 21, 2007 | 02:04 PM
.::B00stin2High::.'s Avatar
Default __ Replacing Fuel Pump on '02 Civic __
Has anyone done it before?? I've been told you can get to it underneath the back seat cushions after taking off the metal cover plate.
TIA.
Old May 21, 2007 | 02:13 PM
PoMoNa_909_eM2's Avatar
Default Re: __ Replacing Fuel Pump on '02 Civic __ (.::B00stin2High::.)
i recommend just taking it into the shop.......
Old May 21, 2007 | 05:11 PM
Boilermaker1's Avatar
replacing a stocker shouldnt be too hard. Pull the seat, remove the seal cover, and relieve the fuel pressure before removing the line, take something flat and preferably nonmetallic and hammer the cover ring off. then the pump boat will come out. You'll need to undo the wiring and the lines, take the cover off, pump comes out, new one goes in, replace lines and reverse.
Return conversion.... whole different animal.
Type-Spaz
14
May 11, 2014 01:36 PM
90 ef
Dec 2, 2009 05:33 PM
IBriaIN
Sep 26, 2007 02:22 AM
turbod16y7vtec
Sep 29, 2002 10:45 AM
