LS/V build, motor sounds too loud? Vids inside.
Finally got the motor all together and installed, no leaks, runs good, needs a tune and break in. My question is that it the valvetrain/injectors sound noisy to me (valves are adjusted to spec), but maybe it's just the fact that I've never heard a motor built like this before .. here are the vids and below them are my setup:
USDM ITR 0.25mm pistons
Skunk2 Pro 1 valve springs, retainers
OEM ITR intake valves
OEM GSR exhaust valves
SKunk2 Pro 1 cams
Fidanza cam gears
ACL bearings
OEM P72 GSR intake mani
RDX 410cc injectors
AEM fuel rail
Aeromotive FPR
Earl's inline fuel filter
Endyn breather kit
AEM UEGO
MSD wires
NGK plugs
Endyn LS/V adapter
Walbro 255HP fuel pump
Crome chipped P28 ecu right now, waiting on my chipped P72.
Thoughts?
SKunk2 Pro 1 cams
Fidanza cam gears
ACL bearings
RDX 410cc injectors
AEM fuel rail
Aeromotive FPR
Endyn breather kit
AEM UEGO
MSD wires
NGK plugs
Endyn LS/V adapter
Thoughts?
its the cams...some have found replacing the LMA with new units helps w/the noise, but when i did mine i didnt notice any difference in sound...my valvetrain is still freakin loud...id be really interested to hear what else can be done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">its the cams...some have found replacing the LMA with new units helps w/the noise, but when i did mine i didnt notice any difference in sound...my valvetrain is still freakin loud...id be really interested to hear what else can be done</TD></TR></TABLE>
Vavletrains on these can make a bit of noise, I know mine does as it's ending its life slowly lol.
When I get around to i'll try the LMA swapping with the rest of it.
Honestly, I wouldn't worry.
ive already tried ITR LMA and am currently running the prelude ones with no luck in reducing valvetrain noise...its probably since the head is 15 years old already
I have brand new ITR LMA's too, pretty sure it's just the valvetrain/cam setup making the noise then, thanks for the info guys! Time to go break it in! hehe.
futrhondaownr
19
Aug 31, 2013 01:57 PM
Riceintegrars
18
Jun 20, 2005 07:57 PM
